disco II transfer case oil check?
  • farmer
    • Nov 2008
    • 24
    where do i find the level and fill plug on a disco II 99 model??what oil to use???
  • stu454
    • 53
    Should be on the side. Looks the same as the diff drain plug.
    90wt diff fluid to fill.
    Stu
    '01 D2
    • Mjollnir
      • Jan 2010
      • 88
      Gear oil
      The correct grade of gear oil for the front/rear diffs and transfer case is 75W-90. Use only synthetic as is stated in the owners manual. Mobil 1 is my choice for those and I use Mobil 1 High Mileage 10W-40 in the engine year round.
