Re: 1999 Disco II 100K
This LR is equipped with the rear air option. Recently, both the blower motors for the main a/c and the rear a/c have stopped working.
The blower(s) will not work at any speed, or setting (A\C or heating).
I have checked all fuses and relays that seem relative to the system, Also, I removed the front blower, connected it to 12V power, and it comes on. Swapped the blower relays....both click and seem fine.
The only part I'm not sure of, is the resistor pack....but my repair DVD states the blower should still work on high speed. The schematic also shows a 40 amp inline fuse (which I can't find) located in the L/S rear quarter panel which "protects" the resistor pack .....but the DVD states the system should still work on high speed.....even if the fuse is blown.
Since, both the front and rear AC systems have failed...... is there a common relay, etc. that would affect them together.
The only answers I seem to get is to check the fuses and relays under the hood and in the passenger compartment.
