Help! Had pinging in car now white exhaust that doesn't go away and when in park and accelerate seems as if moisture/water comes out as well
white exhaust
Do a leak down test, skip compression check a leakdown will give you more info. Under a $100 you can buy the gauges. Where are you? Metrowest I can do it for you. Pull the spark plugs and see what they look like, if one is cleaner than all the rest (steamed off) then your pumping coolant into that cylinder, could be a couple of things.
Why was it pinging?
Could have slipped a liner, head gasket, cracked block? Hard to tell without some more diagnosis. Hopefully something much more simple.
Leak down!Comment
sorry so long on reply just had head gaskets replaced, seemed fine but has a weird vibrating sound when continuous speed or when slowing down on acceleration. But if totally let off gas stops the sound until a continuous speed again. Plus a thudding sound every so often. My husband thinks flywheel as seems to be for acceleration? Does well doesnt lose power on hills but starts a strange ping? again no loss of powerComment
