Does anyone know where I can get adapter plates to fit a 350 in my series? I am open to options but was thinking keeping the GM engine and tranny together and finding an adapter plate to fit the transfer case for the 4X4 system.
350 Chevy in a series
Tags: None
Call Advanced Adapters and talk to Matt Jackson, he has developed an adapter that essentially makes the Series Transfer case's like a Dana 300, so you can then yse any of the transmissions that can be swapped to the Dana 300 with the Series T case. (at least that is my understanding of the adapter.)
the small block v/8 fits tight and has to be installed ascued to give clearence to the steering box, ive used many scotty adapters (now out of buisiness) for installing chevy 292 6-cyls to the land rover trans,the 292 works out great for fit and power but have made adapters from a 60s 70s chevy school bus which has a factory adapter between the v/8 engine and transmission which will give you a good start for making your own adapter for chevy bolt pattern.....Comment
3 years ago i built a 67 109 with a chevy conv i used a chevy engine 700R4 auto trans w/od and an S-10 transfrer case that put the front propeller shaft in the right place, problems i encountered were: 3 x members had to be altered and the trans x member had to be completely removed and fabricate a new one to accomedate the GM trans,the propeller shafts had to be cut, spliced and balanced, rear shims added to change the degree of the rear diff, i used a micro lock for an e-brake,and howell ind makes a harness for the OD that just plugs in,and a trans am floor shifter and cable, but after completing all that the biggest problem i encountered was the tremendous torque of the GM drive train was so much that it overpowered the 109 6-cyl brakes with duel master and servo (all new) but maybe now some one makes an up graded brake system which replaces the LR brakes and will stop this frieght train.....Comment
I really think Matt Jackson/Advaced Adapter's adapter is worth looking into- you could use just about any transmission with it. Otherwise there are adapters out there for attaching a T18 or a NP435 to the Series T-case.Comment
i'd love to have that kind of power then i'd have an excuse for my brakes not stopping my 88. have you looked at the 4 disc brake conversions for the series?'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
04 DII
08 D3 (LR3)Comment
the guy has it mid way down:
http://www.landroverexchange.com/listings/Advertisement to SELL; Product: PARTS; Price: 299; (Currency: US Dollars)
GM ADAPTER BELLHOUSETO SERIES GEARBOX/ OTHER PARTS GOODIES F
1 gm v8/6cyc/v6 conversion bellhouse bolts directly to series 2/3 gearbox alum/i beleive it is a scotties pic ava 299/ r 380 transmissions 350ea 4 ava/coil conversion kit 4 springsall bolts brackets to replace air bags only 299/1 good 3.5 v8 rover 500/ 1 zf 3spd 450/230transfercases 250/cores 100/discovery 1 doors free call /new sunroof in box100/series differentals 350/disco 350/range 350/coilpack 99/abs block 75/abs computor 75/airbags99/dashclusters classic /disco 75ea/injection units wmeters75/range lower gate 75/fairly winch 999/pto 500/alum truck campershell 109/110/500/cleaning barn out..email w/needs thanks /walt707-546-2150 email for pics and shipping is ava on most items also have series 1/2/3/defender disco/range/parts and s1 who;e 80 fs/101fc fs
WALT FORD.Comment
Gunny-
what adapter are you looking for exactly?Comment
04 DII
08 D3 (LR3)Comment
I think you need to go directly to AA for those, I don't know of anyone with one yet. They are still really new.
What engine/tranny are you thinking abut using?Comment
4.3L V6 and not 100% on the tranny yet. Most likely a slush box but i haven't made up my mind. Need to see what is available as far as the adaptor is concerned.First but gone: 91 3 door Disco "White Rhino"
04 DII
08 D3 (LR3)Comment
