Happy New Year!
My Series IIA has developed some clutch problems. Started lurching forward or back when starting in 1st or reverse with clutch depressed. Then yesterday while driving I lost clutch pressure for the most part and had to shut her down to get back in 1st gear at a light. Today I drove and had some pressure, but gears engaged with very little clutch pedal travel and had to shut down again at one light to get her in 1st. Looked at master and slave and didn't see any obvious leaks. Topped reservoir off, but it did not seem low enough to have sucked air in the system. Any ideas? Not sure if it just needs to be bled or if the clutch itself is going bad - only have had that happen once and it was completely different symptoms. Also, I noticed that my clutch pedal is not coming up to full height when released.
Thanks in advance for any ideas.
Jack
Jack
