Gambrinus--Unfortunately, don't know many people about....especially that want to come over and play Rover! BUT, great idea. I will disconnect the fuel line at the carb and try cranking it (will put the line in a jam jar....if there is fuel in it, then that's that). I did clean out the sediment bowl when the pump was off during all the work I did (and replaced the filter and sealing ring), but another idea to check easily.
Bmohan--Another great idea that I would not have thought of....the pick up line. No fuel filter (never was....but am going to add one now). I felt like I was on a mountain safari....bunch of deer walked by while I was stranded!!!!
Keithg--I forgot the size of the gauges. You should have the oil pressure gauge in the same location on your 73 I think....the other 2 holes in the cluster are the same size as it. I was thinking the diaphragm also in the mech. pump.....rigging up the electric won't take long. May leave it in place, as it may help a bit with vapor lock I used to get.
Thanks!
Julian
PS Any thoughts on the coolant leak??!! Tstat housing a good bet and redoing it with the permatex??
Thanks!
Julian
Forunately/unfortunately, that pesky coolant leak showed up....was able to get back to the garage....it is (pretty sure) not at the tstat triangular housing part, but on the side part of that same housing. I also think the (new) stainless bolt broke in the housing making it loose. So, anyway, I THINK success might be on tomorrow's horizon!!
