I have a 73 Series III I have been slowly resurecting and before I put the tub back on I need to install the brake lines and finish hanging the exhaust. The exhaust is all bolted in place but I do not see any obvious holes or brackets for hangar locations. I vaguely remember there being one on the tail pipe and I assume there is another around the center cross member. I have looked at the drawing on RN's parts page and I can make some guesses about how to set it up. Curious if anyone has some pictures of the mounts. The truck is a bit of a mut now because it has a series IIA frame with Series III components.
Also, any recommendations on running the brake lines? I see the RN brake line kit is just a bunch of line coils needing to be bent to the appropriate shape. I can easily buy a spool of my own line and fittings....or is it a lot easier to buy as many of the prebent bits? opinions and thoughts appreciated.
. What is the paint on that? I always thought if I were going to go nuts I would paint the axles a Marine green. I dislike black as it is just so hard to see stuff when working on them or looking for leaks...though I understand it is the appropriate color for a full true restoration.
