It got cold here. My starter spins but does not engage the flywheel. Is it safe to assume that the cold has made the starter cog not slide on the shaft? Is this easy to fix?
Starter Not Engaging
X2^
I was able to pull the starter out enough to expose the shaft (to wiggly it out past the downpipe and totally remove is a PITA) and spray some cleaner on it. Kept it working for a couple of months until it gumed up agian.04 Disco, Gone-Disco died & so did mine
'72 S3 88 - Leakey & SqueakyComment
I suspect the main seal leaked before I had the engine rebuilt. Only became an issue when the temperature went below -27C. I will try the carb cleaner approach. I noticed in the green bible there is no mention of lubricant. Is it supposed to be just clean and dry?
I can not move it into the garage until the weather warms a bit and the starter starts engaging again. I guess no Rover for me until next week.____________________________
1959 Series II 88"
"Grover"Comment
If you turn your steering wheel fully to the right, there is plenty of room for the starter to drop right out.When you have the nuts off, pull the starter out and up,Then drop the bendix down. Goes in in the same manner.Comment
