Working on pulling the gearbox/transfer box out to rebuild. Had tremendous amount of difficulty taking out / disconnecting both front and rear prop shafts.
The bolts where facing the direction of the prop shaft, it proved to be difficult to remove as they were pretty stripped and made a difficult job in pulling out. Where they facing the correct direction? Or should the bolts be facing the differential?
While I have the prop shaft out, I was thinking of dismantling and sending some parts out for powder coating. How difficult is the removal of the universal joint? Is this recommended, how can I tell if this needs replacing. I figure if it does, then dissemble and powder coat, if not, then maybe just clean and paint. Any thoughts?
1959 SII 88"
1959 SII 88"
