I'm in the process of rebuilding my clutch master cylinder and upon pulling it apart I found that the spring has a resin-like substance cast onto the end. The green bible shows that there should be a metal clip at that end of the spring instead. Has anyone seen this before? The resin appears to be decent, but it is chipped a little and as long as I have it pulled apart I am more inclined to make it as it should be. I'm not sure if this is a replacement/hack that a previous owner did or if it is a standard replacement item. If not, is there anywhere to get a replacement spring and metal clip?
Thanks in advance!
Thanks in advance!
