In the process of gearbox rebuild. Just got the transfer case off the car, and will work on its rebuild and then get the rest of the gearbox out.
When performing a rebuild, do you just clean all the stud bolts or do your replace with new?
I have found on some sites the larger Stud bolts but have been unable to find the smaller ones that fit the sump. I was missing a couple. Any suggestions?
Also do you replace all the bolts or just clean the existing ones?
Are all the bolts nylock? I could not tell as there are covered with so much gunk.
Thanks.
Thanks.
