Lost High Range
  • Escargo
    • May 2008
    • 65
    Lost High Range
    This evening while rolling thru a green light, I downshifted to 2nd, let out the clutch and had no power to the wheels. No grinding or funny noises. I pulled off the road, luckily. Abit later I thought to try 4 wheel or low range and found I could engage low range to move, but I didn't feel like going 8 miles home in low. It's a 64 lla shorty with the "new" high ratio transfer case, maybe 2000 miles on it. Any thoughts?
    Hans
  • JimCT
    • 518
    broke a half shaft
    I bet you will find have front wheel drive if you engage 4high
    1963 Unimog Radio box
    1995 LWB RR
    • Escargo
      • May 2008
      • 65
      That's what I initially thought....but The 4 wheel lever would not stay down and engage.
      • I Leak Oil
        • 1796
        Sounds like a linkage issue.
        • 73series88
          • Oct 2009
          • 587
          yeh
          make sure nothings in the way
          i was riding around before i got the lever boots on.
          a ratchet had worked its way down the hole and popped the shifter into neutral. and was was keeping me from putting it back into gear.
          quick fix for me.
          aaron
          67 series 2a 88 RHD sold
          88 RRC sold
          60 mga coupe
          • Escargo
            • May 2008
            • 65
            Nothing as simple as that, darnit. It did go into 4High this morning and got me home. I don't know why it didn't want to last night. Must be the half-shaft. Any recommendations on what to put back in there? I can't believe one broke just with normal hard surface driving.
            Hans
            • I Leak Oil
              • 1796
              Could very well be a half shaft but that has nothing to do with your range lever not working right. Have you tried it in 2wd high range yet to see if it's working again?
              • Les Parker
                • May 2006
                • 2020
                1/2 shaft
                Hans,
                Let us know how it all pans out.
                • Terrys
                  • May 2007
                  • 1382
                  I've never heard of a broken halfshaft repairing itself. Must be bionic. They don't always go with a bang either.
                  • JimCT
                    • 518
                    4 high range
                    do not think he meant it repaired itself, but that he got in into 4-high and now has a nice FWD rover
                    1995 LWB RR
                    • Moose
                      • 226
                      To get it to stay in 4WD, push the yellow knob down and hold it, then pull the red knob back into low range, then forward into high range. The yellow knob will hopefully stay down. After not being used for some time, my 88 would exhibit the same symptoms and repeating this little procedure a couple times would free things up again.
                      As for those pesky half-shafts, sometimes if they are already tired, it doesn't take much at all to snap one.
                      Brett
                      Series 3 88 Diesel Soft Top
                      Ex-Mod 110 Tdi
                      • Terrys
                        • May 2007
                        • 1382
                        So Jim, are you saying this makes sense to you?
                        • JimCT
                          • 518
                          front wheel drive
                          in 4 high with a broken half shaft you still have front wheel drive
                          1995 LWB RR
                          • Terrys
                            • May 2007
                            • 1382
                            No Kidding? Wow, the things you learn after 40 years and as many Land Rovers.
                            What I was talking about was the fact that it WOULDN'T go into 4H the night before, but now WOULD, Therefore his assumption was it must be a halfshaft.
                              I don't think this needs explaining, but the halfshaft diagnosis was presumably the result of now being able to put the transfer case in 4 high and motivate the vehicle (implied), and not the mere fact that it now properly shifted into 4 high.
                              Structurally speaking, your'e right. There should have been some sort of connection between 2 seemingly separate, disconnected thoughts in the same paragraph...
