Ive been trying to sort out why my 109 has not be able to shift into 2wd since the rebuild. Checked and rechecked all the obvious stuff. Im sure its something i did wrong while attaching it last winter. I think the problem is with the red lever action. I cannot get it to disengage 4 when i pull it all the way back. The yellow knob pops back up like it always has but its still in 4 hi. Ive been staring at the picture diagrams in the green bible trying to visualize how it all works in there. I suspect that one of the pins that hook in that pivot point was not in properly. (im making up terms for the parts) Im having a heck of a time trying to get the housing back on now after seeing how it needs to go together. I cannot get the shaft that the 4wd pin goes into to come out the front of the housing. Im fighting the springs trying to slide it back onto the studs and once i let go, the housing moves (springs) forward again. Is this because 4wd is still engaged?
I would think it would go on much easier that it is. I probably didn't make much sense to most people including myself. If anyone has an idea of what im up against im open to any ideas. I spent all day in and around the truck today and no luck...
thanks, mason
thanks, mason
