Project to go on hold
  • kwd509
    • Aug 2010
    • 190
    Owing to an unexpected and serious health issue for my wife, the rover restoration will go on hold. The duration of this break is entirely unknown. Life is quite unpredictable.
    My question here is whether there are any specific recommendations to place a project in suspended animation, aside from organizing and labeling the current batch of loose pieces. As this vehicle did reasonably well sitting in a field for many years, I can't think of anything special, but figure some folks might have suggestions.
    Lord willing, her health will return and the rover will ride again.
    Thanks.
  • rdsrover
    • Jan 2012
    • 28
    Enjoy your wife's company. The rover will keep.
    • 4flattires
      • Aug 2007
      • 424
      Wishing all a speedy and full recovery.
      Pictures.....take pictures....oh...and then save them in a logical manner.
      64 SIIa 109 all stock
      69 SIIa 88 all stock
      Old tractors
      New Harleys
      Old trucks
      • mearstrae
        • Oct 2011
        • 592
        Sorry to hear of your wife's trouble, pray all will turn out well. The only thing I'd worry about is the engine, a little gear oil worked into the cylinders by turning over by hand, will prevent a lock-up. [I use old fashion gear lube for this, as it's sufurated and pentrates the metal better than motor oil or others. Old trick used in industry equipment storage.]
        '95 R.R. Classic LWB
        '76 Series III Hybrid 109
        '70 Rover 3500S
          Keep it dry, turn the motor once in a while. Drain the radiator coolant and gas if you haven't all ready.
          You may find that you want to keep certain parts of it around to work on. It's good therapy.
          Best wishes.
          • kwd509
            • Aug 2010
            • 190
            Thanks for the suggestions. Really helpful stuff. Will keep right front swivel ball assembly handy in case I need a little grease therapy.
            • lincoln lass
              • Jan 2012
              • 36
              Hope the wife is ok and makes a speedy recovery.
              • LaneRover
                • 1743
                I concur!
                I also like your idea of keeping something to fix nearby in case you need 'grease therapy'.
                • 73series88
                  • Oct 2009
                  • 587
                  take care
                  aaron
                  67 series 2a 88 RHD sold
                  88 RRC sold
                  60 mga coupe
                  • kwd509
                    • Aug 2010
                    • 190
                    Originally posted by LaneRover
                    I concur!
                    My son and my wife concur as well. A recommendation for Seafoam (or something similar) into the pistons, and I will likely do......then I will tidy up loose ends. But there is some interesting pressure from w/in family to limp along with rover instead of resigning to a full stop.
                    Never a dull moment.
                    Thanks for all the advice and help.
                    • cedryck
                      • Sep 2010
                      • 836
                      Sorry to hear. My wife was diagnosed with Multiple Sclerosis while I was restoring my beloved Cedryck, 1965 ex MOD. I put my project on hold as we sorted out our lives. Listen, your rover will understand, and when your life is back on track, get back to work. They are sturdy lads, and keep well. My very best wishes to you and your wife. Cheers.
