1972-series 3 - 88. My rig came with electric cooling fan mounted on the outboard side of the radiator- no mechanical fan or shroud installed. Experience higher then normal temps on summer days during highway speeds. just installed a metal fan on the front pulley and now experiencing much better cooling with no effect on power. Question- do i really need the shroud installed? If so were can i locate an original one. any advice would be great. john
Series 3 radiator shroud / cowl
Tags: None
It's not really necessary to run a shroud. However, it will help the cooling that much more. So, if you are towing, hill calming, or running at higher speeds and notice that you are running hot, than the shroud might fix that.
I ran an electric fan for a few weeks. I didn't really care for it that much. But, others have and love it.
Birmabright Brotherhood
Clint Rankin - 1972 SIII SWBComment
1971 SIIa 88" NAS Dauntles V6
1974 SIII 109" RHDComment
For what it's worth.
If your timing/ignition is off, you'll run hot.
Carb running lean, you'll run hot.
Thermostat stuck or PO put a "winter" one in, you'll run hot.
Radiator gunked up or plugged, you'll run hot.
Blown head gasket, you'll run hot.
At highway speeds tells me your running full throttle. If all is right with the truck the electric fan is more than enough at speed. The air blowing through it will keep it cool. An electric fan is great for slow stop and go driving and it's pretty much just along for the ride at highway speeds.
WARNING! I'm by no means a "Rover Guru" just have owned alot of old cars and trucks.
1978 MOD 109Comment
No, you don't need the shroud but as stated earlier, it makes it more efficient.
Perhaps a stupid question but is you're electric fan a pusher like it should be?Jason
Electric Fan is a pusher- Agree with whiterrabbit. going to leave both fans on. Can not hurt to have redundant systems just in case the electric fan craps out. a overheated engine = trouble. Can any point me in the right direction on an original shroud/cowl set up. thanks for all your input. john72 series 3 88
74 bmw r90sComment
i by all my parts from the host. i was looking for original equipment to keep the rig as stock as possible. RN only has the proline line for this product. thanks john72 series 3 88
74 bmw r90sComment
Not so sure that electric pusher is stock. Or an electric pusher with an engine-driven tractor. You're going to have to remove that electric fan to keep the rig as stock as possible. Then you'll have to find a Rover-manufactured bent tin shroud and fit it.
I'm sure the proline piece of bent tin will look and function exactly the same as one that rolled out of the folding plant in the UK 40 years ago.--Mark
My 1970 came with a plastic shroud /cowling - and a small metal guard around the top.Not so sure that electric pusher is stock. Or an electric pusher with an engine-driven tractor. You're going to have to remove that electric fan to keep the rig as stock as possible. Then you'll have to find a Rover-manufactured bent tin shroud and fit it.
I'm sure the proline piece of bent tin will look and function exactly the same as one that rolled out of the folding plant in the UK 40 years ago.Comment
Yeah, mine probably did too. I threw it out so long ago I can't remember. Reminds me that I bought a replacement shroud off a member here a few months ago that I've still got to go pick up.--Mark
04 DII
08 D3 (LR3)Comment
