Exhaust leak, stud replacement
  • cinelliguy
    • Dec 2011
    • 13
    Hi to all,
    New to the forum. New, 3 month owner of a 1969 109, 2.25L. I had/have an exhaust leak and during repair effort, I have snapped off the center top location exhaust stud. See attached image.
    Question is, can anyone give me the length measurement for that stud? What I have left is 42mm, so if I can get the real overall length then I will know better what I have to do by way of get that last bit out of the head.
    Guy
  • cinelliguy
    • Dec 2011
    • 13
    No answers from the group, I understand. Not like everyone has studs laying around for measurement.
    I ordered a full set of studs, so I will get my measurement that way. I will post the final answer when they come in and I start the project.
    ~ Guy
    • LaneRover
      • 1743
      It happens to us regulars too occasionally (no responses)
      Broken studs seem to happen all the time
      I had a truck where every time I changed the exhaust downpipe I'd break a stud, other trucks where the bolts always came out just fine.
      Best of luck!
      • masonater
        • Nov 2007
        • 329
        I know its not the best advice but i just said the heck with it and bought a new exhaust manifold, studs, and down pipe. I tried drilling out 2 broken studs of the 3 but the flange surface was so pitted and rusty. i just chucked it and spent 160 bucks for new stuff.
        anyway i was staring at a bag of the studs reading this post so i measured one for you. I got overall 44.6mm. Hope this helps you out
        1970 Series IIA 109 EX-MOD
        1971 Series IIA 109 EX-MOD
        1982 Mercedes 300TD
        1989 RRC
        1993 D110
        1994 RRC LWB
        1995 RRC LWB
        1995 RRC LWB
        1995 Disco
        1996 GMC 2500 Suburban
        1996 Disco
        1997 Disco
        2001 RR P38
        2005 LR3 HSE
        2006 RR HSE
        • tmckeon88
          • 142
          There are companies that offer stainless hardware for the exhaust manifold, which can make the next disassembly easier. I replaced my exhaust manifold about 4 years ago and took the opportunity to replace all the mounting studs with stainless. I little research and a well-stocked hardware store and you might be able to get many of the studs locally. The threading is standard, I think- someone correct me if I'm wrong! I also used brass nuts to secure the downpipe to the manifold, but stainless would work there too. Be generous with the anti-seize compound when you reassemble.
          Tom
          1969 Series IIA 88"
          • LR Max
            • Feb 2010
            • 315
            If I remember correctly, its a standard sized exhaust stude. NAPA usually has them in stock, as well as different length ones. Since they are cheap, just go buy a few of em. Heck even get an extended one so its a little easier.
            • cinelliguy
              • Dec 2011
              • 13
              "masonater" ~ thanks buddy. Looks like I have just the tip still in the hole. "tmckeon88" thank you too! Looking for stainless studs tomorrow!
              • tmckeon88
                • 142
                No problem- I bought the set of stainless exhaust fixing hardware from British Northwest Land Rover, but the sizes can be sources locally. As I recall it was a bear to get them all back in because the ones under the manifold are very inaccessible once the intake/exhaust manifolds are back in place. I did a lot of blind contortions and mixtures of sockets and extensions to reach them and even then turned about 5 degrees at a time. Months later on I noticed a couple of studs/bolts had fallen out! Not usually a problem with manifold studs. But I'm confident that with the antiseize on there I can take it apart again. There's a gasket between the intake/exhaust manifold you should take the opportunity to renew as well.
                Tom
                Tom
                1969 Series IIA 88"
