Diesel Ignition Switch and Glow Plugs
  • AirmanPika
    • Mar 2012
    • 29
    OK so I finally got an proper owners manual for my Land Rover thats in english and realized that my ignition switch is not the correct type at all. My rover has a 3 position switch which is preventing the glow plugs from heating up correctly. I suspect this is a big reason why I have to jump my rover and crank it for an extened period before it finally starts.
    Anyway I think I sourced the correct replacement as being http://www.roversnorth.com/store/p-1...ch-diesel.aspx
    I could go the more expensive genuine part way but thats not really a big concern for me.
    Also, has anyone ever sourced replacement glow plugs from US shops like Advance Auto Parts or so on? I'd like to replace my glow plugs, especially to the newer types if possible that heat up faster. I've seen some of those kits to do this, but they are kind of rediculous price wise and then you have to get them shipped from the UK.
  • yorker
    • 1635
    It is unlikely in the extreme you'll find glow plugs at Advanced Auto. Just buy a set of these:
    Find many great new & used options and get the best deals for Land Rover Series 2a 3 2.25 Diesel Engine Parallel Glow Plug Upgrade DA1057 at the best online prices at eBay UK! Free delivery for many products!
    Land Rover UK Forums
    • Lalo88DK
      • Nov 2009
      • 116
      A Series diesel ignition switch has only three positions, you need to hold the key just before the starter kicks in and hold it there while you watch the glow plug light turn on and count to about 10-15. (Just between position 2 and 3). Turn the key to second position and then turn the key just a little bit more and hold it there, while the glow plugs do their job and then press it just a bit more to start the engine. They don't have a timed glow relay.
      If the glow plug light don't turn on you probably have a defective glow plug. The glow plugs are series connected, so if one doesn't work, none of them work.
      I have replaced mine with the later type, then you don't have to use the resister coil either.
      • AirmanPika
        • Mar 2012
        • 29
        Ah well that did it. I guess the manual just confused me as it made it sound as if there was an additional stop before the starter. I believe mine is working as the light came in dim but not bright as stated in the manual. Its still being stubborn on the start and need a good deal of cranking and connection to another car before it goes but I'm hoping to solve that in the next few months. I finally have a garage to put it in so I'm gonna start the teardown and will do an engine rebuild at the same time.
        • morgant
          • Jun 2009
          • 170
          How's the battery? I had similar issues (dim cold start light & eventual clicking of the starter) until I replaced the battery with a Group 27 with 800CCA (cold cranking amps). If you need to jump it to get it to start, that's where I'd begin.
          rikuwoiku — to travel overland.
          1982 Series III 88" (RHD w/2.8L Daihatsu diesel)
          2002 Discovery II SE
          CentreSteer.com — A podcast by, for, and about Land Rover owners. (Panelist & Content Producer)
          SeriesParts.com — A master list of parts, part suppliers (our gracious hosts included), and repair shops for Series Land Rovers.
          • yorker
            • 1635
            If you are going to rebuild this thing you'll definitely want the glow plugs I linked too. They are a lot better than the original coiled element type.
            read these links:
              I despise forums where you have to be a member to view their secret information...
              • antichrist
                • Mar 2009
                • 272
                If you in fact have a petrol ignition switch, you can always just install a momentary push button switch to operate the glow plugs. I did this for the pre-heater for Perkins conversions.
                Tom Rowe
                62 88 reg
                67 NADA x2
                95 D1 - R380
                95 D90 - R380
                97 D1 - ZF
                • yorker
                  • 1635
                  Thats too bad. Its a good forum though.
