You all have been pretty patient with my questions about this swap for which I am grateful. But now the time has come for action. I am heading over to the SIII donor vehicle to pull the parts I need this Saturday.
For clarity:
I plan on pulling the bellhousing and the gearbox from the SIII. I understand that my transfer case should mate up with the SIII gearbox. Do I need to pull the SIII transfer case as well to make this all work?
Mine and the donor are both 4 cylinder engines. I understand that the SIII clutch mechanism does not function in the same manner as the SIIa so there might need to be some reconfiguration. But I am still not clear if I even need the SIII bellhousing or if I can literally just replace the SIII gearbox with mine and keep everything else the same. (bellhousing & transfer case).
Thanks for the final clarification!
For clarity:
