Stage1 alternate CV successful so far
  • slorocco
    • 208
    Well, no pics but….
    I’ve finally finished the substitution of the Stage1 CV joint with the early defender AEU2522 CV joint. Looking on one UK website that has both part numbers, there is a significant price difference 30 pound vs 300 pounds. So it was well worth investigating an alternative.
    Looking at both CVs externally they look virtually identical with the only apparent difference being the length of the splined shaft. I did not measure the exact difference but can tell you that the AEU2522 shaft is just short enough that it does not protrude out of the end of the drive flange when installed. In fact the splined shaft sits about 1/8 to3/16 of an inch short of the outside of the drive flange.
    My plan was to use a large fender washer and an appropriately sized bolt with some loctite to hold the shaft in place. After searching around I could not find the correct bolt. 10mm was too small, 12mm was too large, 11mm may have worked but could not find one locally. SAE sizes also did not work. The final solution was to run a 7/16 fine thread tap down the hole and use a 7/16 bolt with a large fender washer and some loctite. Got it all zipped up at SCARR and ran a full day of trails with no issues.
  • disco2hse
    • Jul 2010
    • 451
    Sounds great. And yes, some pictures would be useful.
    Does mean you also got the disks, or are you still using drums?
    Alan
    109 Stage 1 V8 ex-army FFR
    2005 Disco 2 HSE
    • slorocco
      • 208
      Still running drums. My front axle is actually a Salisbury front axle but everthing starting with the swivel balls outward are Stage 1 parts for some reason. I'll get off my lazy butt and go snap some pics for you.
      • slorocco
        • 208
        Pics added
        You can see in the first pic that the shaft does not protrude past the drive flange as intended. The next two pics show the "fix" to hold the shaft from wandering.
        • disco2hse
          • Jul 2010
          • 451
          Thanks. Much appreciated.
          Would you have a 101 FC or One Ton front end then?
          Alan
          2005 Disco 2 HSE
          • slorocco
            • 208
            I believe it's a one ton series III salisbury front axle. Swivel balls bolt on and it's got 4.7:1 gearing but it is a bit wider than the standard series width.
            • yorker
              • 1635
              I'm pretty sure Series III 1 tons had Rover front ends- maybe you have one of the front ends off of a Shorland? In any case it is cool- take some more pics of the front end if you can.
              Land Rover UK Forums
              • disco2hse
                • Jul 2010
                • 451
                That would be right. The One Ton's with the 900x16 tyres needed the stronger front diff.
                Alan
                2005 Disco 2 HSE
                • yorker
                  • 1635
                  Yeah I guess the suffix c and later Series III 1 tons had the Rover front axles. When I last knew all of them were thought to have had them.
                  • slorocco
                    • 208
                    I'll dig up some more pics or take some and post. I've made some modifications to move the springs above the axles and to move the steering linkage above the axle as well. Oh yeah I also added power steering.
                    • yorker
                      • 1635
                      Wait- is yours the 109 with the 4bt?
                      • slorocco
                        • 208
                        Yup. '63 109 station wagon with the 4BT.
                        • yorker
                          • 1635
                          Weren't you the one who stopped in to see Robbie of Draken Offroad and went offroading there? I think my brother saw your truck there.
                          • slorocco
                            • 208
                            Yup, I was up there last summer. Had a great time wheeling there on Robbie's property
