So, my quest to find a SIII bellhousig/gearbox/transfer case was a success. Pulled from the donor today and now she is sitting in my IIa 109. Unfortunately when I when to install the fairey drive I took out the gear as described in the actual online manual, however, the main shaft is too long for the fairey to mate up. So, is the IIa fairey drive not mean to work on a SIII? I hope I don't have to start swapping out shafts to make this thing work. If so, I might have a fairey drive for sale......
Fairey Drive Swap - IIa to III Not Good
Did you use the right lock washer when you reinstalled the Fairey drive clutch or did you try to reuse the existing lock washer? That could keep the OD from seating all the way.
If you did use the right washer, try turning the parking brake drum back and forth while you push the OD into place. Should slide in.Jason
I tried to put the OD on the SIII just like it sat on the SII. I didn't take anything off or out of the OD. Should I have? It is like the shaft is to long in the SIII and it didn't seem possible that it could even engage the gearing. It will not mate up because it doesn't seem like it goes into the housing far enough. I will have to look at a diagram of the OD to see what lock washer you are referencing.1969 Series IIa 109
She is ugly but she is mine...Comment
I used the same lock washer when reinstalling. I see what you mean. If that lock washer is all that is holding this back that is pretty impressive. Oh, man....looking at the manual (http://www.faireyoverdrive.com/manual.htm) I thought that the OD unit replaced gear "D" as shown on page 8. I never put that gear back in....nice. Okay. Will try that then. Still not sure if I have the right lock washer though.1969 Series IIa 109
OK, so you need to remove the gear off the SIII transmission.
Remove the clutch/gear from the SII that came with the OD.
Reinstall this same gear on the SIII transmission.
You can just file down the tabs on the old lock washer to make it fit if needed. They need to be shorter IIRC....Jason
Let me start off with some pictures of what I am dealing with. It will help me with help with the terminology here. See attached photos.OK, so you need to remove the gear off the SIII transmission.
When you say remove the clutch/gear from the SII that came with the OD what do you mean? I pulled the entire unit out in one piece...and it seemed to directly engage with the big gear shown in the picture of the SIIa.
Derek1969 Series IIa 109
I can pull this piece out of the OD.Let me start off with some pictures of what I am dealing with. It will help me with help with the terminology here. See attached photos.
Holy cow! you're missing part of the main shaft from the IIA! Just a guess, if you look inside the big gear on the end of the OD do you see it in there along with the OD clutch?
If you remove the output gear from the SIII unit you'll see what your IIa should look like. The OD clutch replaces that output gear.Jason
Oh no...so the main shaft in the IIa is supposed to be as long as the main shaft in the III?Holy cow! you're missing part of the main shaft from the IIA! Just a guess, if you look inside the big gear on the end of the OD do you see it in there along with the OD clutch?
I am away from the vehicle until Friday....will have see if the other piece is still in the OD.
Thanks! It is starting to make some sense now.1969 Series IIa 109
yep, the other end of the shaft is still in the OD. Probably not good. Not sure how anything could seize up to break the shaft. The end that goes in to the OD just sits on a bearing right? What the heck could cause this???1969 Series IIa 109
If that is the case then I guess I am out of an overdrive. I understand them to be a very expensive rebuild...
How easily is the large gear on the OD supposed to spin? Pretty easily and freely by hand?1969 Series IIa 109
That might not be the case--I'm just trying to work out what would cause such a failure of the mainshaft. You'll have to determine the cause by exmining the parts in front of you.
Out of curiosity, were you able to get the end of the shaft out of the overdrive yet?--Mark
