Brake Servo/Booster Question
  • sizod
    • 43
    A couple of times now the truck has stalled out and the culprit seems to be that crap got stuck in this hole on the brake servo. first time was some leaves, second time was an old plastic bag that some how came up in to the engine bay. Is it suppose to open like that? or is there a breather/valve that should be there. Thanks.
  • knac1234
    • Nov 2010
    • 442
    Definitely should be plugged, but no valve, just a plug. I used the allen screw/plug out of my old servo...... think it was 3/8" coarse (double check that!).
    Julian
    Julian
    72 Series III NAS
    03 Disco
    65 MGB / 73 MGBGT
    71 RHD Hillman Super Imp
    • sizod
      • 43
      Hi Julian, I'm confused, when I plug the hole (with my finger) the truck stalls out?
      • jac04
        • 1884
        ^^You have a giant vacuum leak, and your carb is probably adjusted to compensate for it. After plugging the hole, go back & readjust the carb.
        • sizod
          • 43
          Thanks!!! I have no idea how long its been missing, I might have been driving like this for years! 3/8 corse and a tune up, I'll report back..
          • sizod
            • 43
            yeah.. temporarily plugged it with a 3/8 bolt and about 15 washers until I can find the correct plug. retimed and readjusted the carb, runs better than every.
