Hey folks,
We all know what will happen when I post this right? As soon as I want to get back on track with fixing or preventing other stuff, something new breaks
So... knocking on wood....
I'd like to address the darty steering I've lived with since owning my truck. To the eye, the tires are VERY toe-in, and others have commented on them before too.
I've read up on the adjustment process and while I haven't done it before, think I understand it.
Before I set up a fancy jig, or put paint on the tires or something equally complex, is there any reason I can't just use a known point on the treads? For instance, the tread pattern has three groves running the circumference of each tire. Couldn't I just measure from the inside of the middle grove on each tire?
I understand the specs call for a pretty specific amount of toe and a variation on a nub or notch in the treads would change that. But, I'm starting from pretty far out of spec and I could do my best to make sure I was on a nub or ridge on each tire when taking measurements.
To that end, this video uses that method: http://www.ehow.com/video_2327639_me...alignment.html
Thoughts, suggestions, lessons learned?
