What is the designed use for the Fairey? In regards to using it for an increased highway speed (increased and speed used as relevant terms!), is it designed not to be engaged until you get to higher RPMs in fourth gear and then you engage the OD at that point? Or is is better to keep it engaged through all four gears from the start if you know you would like to take advantage of the high speed capability?
I have not tried to engage the OD running in fourth gear yet as I just installed the SIII tranny and OD. I would rather not have it all sound like a blender full of bolts if it is not designed to be shifted into OD while underway.
Thanks!
Derek
Thanks!
Derek
