Greetings - I've purchased a 1981 3 door Stage 1 in Holland where I presently live, will be exporting back to the states in July.
I've had the truck for 3 months and am noticing exhaust fume smell in the cabin getting worse over time. I've confirmed that there are no leaks in the system itself - my rover mechanic here has inspected and confirms it is in good shape and tight. So what I'm left with is length of tailpipe which I've extended by 4 inches to get it out from under the rear left panel, but no real change to the smell of fumes. I've got some other issues to investigate such as valve stem seals to address white smoke at start-up, but I'm not certain that remedy will effect the intensity of smell. I've had other series rovers over the past 20 years or so and I'm used to the fact that exhaust smell is the nature of the beast, but have never had a v8 before. Not certain if I just need to expect twice as much smell because I have twice the number of cylinders.
Anyone else battled with these issues? Any advice as to troubleshooting/ remedy?
