All,
So I started a similar thread a while back, and now am ready to do the conversion. I want to use the Delco 96si (96 amp) alternator recommended by Mark. It appears that it is already established that a stock SIII wiring harness will have no problem with this setup.
So.....
-Can't seem to find it. What model exactly is it? Or better yet, what car was it fitted to originally so I can reference the regular auto parts retailers' websites?
-Will it come with a pulley to fit a normal fan belt.....or will it come with one for a serpentine belt.....or none of the above?
-Brackets.....I know Ike sells them, but is it possible to mount it properly in the stock SIII bracket setup near the front left bottom of the engine?
-Any other bits I will need? Spacers for the mounting if not using Ike's brackets? Different plug for wiring to the alternator?
Any help appreciated. I will tackle this in a couple of weeks when I take the wing off to put a new manifold gasket on (noticed an exhaust leak last night). And, if steering work is required, bringing the truck to the mechanic with the wing already off will save me a few pennies!
Julian
So.....
Julian
). And yes, it stays cleaner. Mine slips just a little bit with the single belt also. Just a fine line between being tight enough and too tight, less forgiving than the bottom mount setup. I made a little metal heat shield that goes between the manifold and the alternator to help with the heat issue....in theory it works....
