Gearbox and Transfer box fluid volume
  • Max(SD)
    • Jul 2011
    • 82
    The green bible says transfer box needs 4.5 pints and gearbox needs 2.5 pints of gear oil.
    Are these UK pints or US liquid pints?
    Sorry for the silly question;, but if they are UK then it would be a bit more than one gallon while US liquid pints would be 0.85 gallons.
    Don't want to screw considering all the work that went in the rebuild.
    Also from what I can tell, the recommended oil is non synthetic EP90 wt GL4.
  • mearstrae
    • Oct 2011
    • 592
    Hmmm... You must be thinking of the old Imperial gallon measurement. A pint is a pint and it is 16 fluid oz. or .125 of a gallon and a gallon being 128 fluid oz. You need 72 fluid oz. in the transfer and 40 fluid oz. in the gearbox. Or, 3 1/2 quarts total. Don't be afraid to use synthetic, just get the EP 90 eqivilelent and enjoy somewhat quieter and smoother shifing. Be sure to be on level ground and fill them right up to the bottom of the filler holes.
    '95 R.R. Classic LWB
    '76 Series III Hybrid 109
    '70 Rover 3500S
    • Dietersrover
      • Aug 2011
      • 76
      One imperial pint is equal to 1.2 US. So 4.5 is 86.46 fl.US oz.
      And 2.5 is 48 fl oz US.
      And Stalube Makes GL4 85/90W
      • TeriAnn
        • 1087
        Does it really matter? Just get a gallon of Sta-Lube GL4, the Sta-lube pump and fill each filler opening until the oil starts to come out the filler opening.
        If you are pumping out of a gallon container you cant tell if you have 2.5 UK pints or 2.5 US pints
        • jac04
          • 1884
          Exactly the oil, equipment and method I use. Makes filling the trans & x-fer case easy.
