My SIII 88 has the common problem of bi-metallic corrosion at the seatbelt mounting points. Which is the easiest/preferred method to deal with the issue?
1. Repair the existing body panels in place, and somehow isolate the steel mounting from the aluminum body work.
2. Replace the two side body panels.
3. Find a IIA tub without the corrosion and just swap it out.
