Why are both my series 2 trucks hard to start hot??
  • 1961 109 WAGON
    • 227
    Both trucks. One with a solex the others a zenith. Starts perfect when cold. Once the engine gets hot they both seem to vapor lock and takes around ten seconds of cranking before they will fire.. Any ideas???
    How about your fuel lines? Are they routed in a way that keeps them warm or cool? How's your timing? Any smoke on start up? Color?
    • tmckeon88
      • 142
      It might be a vapor lock issue, which I had on my series IIA a few years ago. I drilled a couple of holes in the underside of the gas cap to allow air to get into gas tank as it emptied, and it cleared right up. In the meantime, when it's hard to start maybe just loosen the gas cap to allow air in.
      The holes were drilled on the inside, not all the way through the cap.
      Good luck.
      Tom
      Tom
      1969 Series IIA 88"
      • 1961 109 WAGON
        • 227
        The fuel line is routed just like they came from the factory. I timed both trucks a year ago. And they were in spec when I checked them. And no smoke upon start up.
        I will try the gas cap trick as well thanks!!
        • 73series88
          • Oct 2009
          • 587
          Mine does the exact same thing
          Aaron
          67 series 2a 88 RHD sold
          88 RRC sold
          60 mga coupe
          • mongoswede
            • May 2010
            • 757
            You might try running heavier battery and ground cables to help boost the cranking speed. You might try putting a check valve in the fuel line just before the carb to keep fuel from draining back. Also you could try insulating the fuel line.
            I should have also mentioned that the better battery cables can improve spark performance. You could also install a hotter coil....are you running points or electronic ignition?
            • bkreutz
              • Apr 2010
              • 408
              Mine's done this for a long time, I figured it was fuel peculating over into the intake putting it in a flooded condition, I'm too lazy to fix it so I just put the gas pedal to the floor when it's a hot restart situation (and keep it there) while I'm cranking, fires right up. I'd call myself a procrastinator but I don't want to rush into anything so I'll make that decision later.
              Gale Breitkreutz
              '03 Disco
              '47 CJ2A
              • yorker
                • 1635
                6.2.2 Hot Operation
                When gasoline vaporises prematurely in the fuel system, i.e., upstream of the
                carburettor jets or fuel injectors, operability problems may occur. The
                likelihood of the gasoline vaporising will depend on engine design, ambient
                temperature, ambient pressure and fuel volatility. Due to the higher vapour
                pressure of ethanol-blended fuels, the incidence of vapour formation in the
                fuel system is more likely than for gasoline fuels.
                http://www.environment.gov.au/atmosp...ubs/review.pdf
                Land Rover UK Forums
                • 1961 109 WAGON
                  • 227
                  I'm running points on both trucks.
                  • antichrist
                    • Mar 2009
                    • 272
                    Not unless the existing ones are in really crappy condition, to the point of the engine not cranking.
                    Tom Rowe
                    62 88 reg
                    67 NADA x2
                    95 D1 - R380
                    95 D90 - R380
                    97 D1 - ZF
