I recently dug into my IIA to change the springs and shocks with a set of new standard (not parabolic) springs and shocks from our hosts. As the simple swap progressed, I uncovered a slew of issues that I have decided to fix from new swivel balls to freshly fabricated footwells. While under the truck, I decided to replace the rubber flex boot on the front propeller shaft, because there were just enough remnants of the previous one to serve as proof that it ever had a boot in the first place. I disconnected the nut on the prop. shaft without difficulty, marked the shaft on both sides, removed it, installed the rubber boot, and reassembled. With the new springs and shocks and freshly cleaned front axle installed, the prop shaft would not reach the front differential. Figured I could add a little slack to the retaining nut on the shaft, but in order to make it reach the front diff, the nut had to be removed completely... obviously not going to work... I found a compromise, but it concerns me.
By putting a floor jack under each spring and taking the vehicle weight off the frame and placing it on the front springs, the shackles would shift back a fuzz, the prop shaft would fit, and the retention nut would thread on about 2/3 of the way down. This concerns me because I feel that if the truck hits a decent bump, the front suspension will be yanking on the transfer case. If anyone has any insight, I would love to hear it. Anything from, "you did it wrong" to "stop worrying, it works".
PS. How important is the 12lbs of drag when re-installing the swivel balls? The shims that came out of mine seemed to be in good shape and i kept them organized planning to just re-install them in the same order. Do I need to re-calibrate them? If so, what tool do I use to measure 12 lbs. of drag on there?
