Brake Line Question
  • milhouse
    • Nov 2011
    • 41
    Brake Line Question
    I'm in the process of installing all new brake lines throughout the Rover, and awhile back I purchased RN's brake line kit (88" dual power brake line kit). My question is regarding the rear brake line joint from the line that runs from the master cylinder to the other side of the bulkhead, and then mates with another line that runs along the frame to the hose just before the rear axle. With the lines supplied in the kit at that joint one line has a bubble flare (with a female threaded fitting) and the other has a double flare (with a male threaded fitting). Can these to fittings be bolted together or is a fitting/union supposed to attach the two? If I remember correctly the old lines both had the same fitting that bolted into a brass union.
    ~Neil
    1974 Series III 88
    1955 Chevy 3200 truck
  • J!m
    • 295
    Originally it was a brass union and double flares on both ends but it sounds as if they found a simpler solution to eliminate the union (one less place to leak)... I assume they thread together with no issues and should seal properly based on your description.
    Check with RN to be absolutely sure, or cut the bubble flare off, slip on the correct nut and double flare it and use the original brass fitting.
    Either way, I'd call RN and see what they say.
    I suggest Silicone brake fluid as it does not absorb water and won't strip paint either... (everything must be super-clean when switching so maybe you don't want to bother). I use it on my (sold) series and also my Defender.
    NOTE: You CANNOT use silicone fluid on a newer truck with anti-lock brakes!!!
    1995 110 Regular
    • I Leak Oil
      • 1796
      Don't all series come with anti-lock brakes?
      • milhouse
        • Nov 2011
        • 41
        Thanks for the information J!m, I did in fact contact RN and it's exactly what you said... they eliminiated the union. I now have all the lines installed and so far no leaks (at least not while using the brakes in the driveway).
        ~Neil
        1974 Series III 88
          Not mine. After it rains or after a really humid night, one of my fronts gladly locks up during the first few uses. The trick is to guess which side it'll be!
          • J!m
            • 295
            Not anti-lock brakes, but rather anti-STOP brakes! Common error, so no problem!
            1995 110 Regular
            • 4flattires
              • Aug 2007
              • 424
              Lets not confuse anti-lock, or anti-stop with semi-stop and random-lock.
              Now, just where did I put that partial can of brake fluid......
              64 SIIa 109 all stock
              69 SIIa 88 all stock
              Old tractors
              New Harleys
              Old trucks
              • I Leak Oil
                • 1796
                If you wait you can save yourself some money. That partial can will soon be full (A little water absorption never hurt anything) so you won't need to buy more.
