Hello Everyone!
I would like to start this post off with a huge thank you! All the advice that I had for the lights, master cylinder, and pinion where a huge help! They have now all been successfully fixed.
Today, however, I am faced with a new, and seemingly large, problem. I have had the car running well for a while and I have been driving it daily and I started to notice a slight sputter/inconsistency during Idle. This problem has become increasingly worse. I can barley start the car now and it will not idle. I thought I had dirty fuel/clogged filter, but today I am not so sure.
The symptoms:
at low revs, in each gear, the car sputters and lurches as it gains speed. at high rpms I can feel it cough ever so slightly, similarly to at low rpms but not quite as noticeable (this too, is getting much worse). I took the air filter off from the carb when I got home today and the inside of my carb is black with soot ( I think exhaust residue). And, when I moved the butterfly smoke came out. Now,my mechanical knowledge is limited, but I do not think that is a good sign. I am wondering If there is anyone that may be able to help me with a diagnosis. and perhaps a plan of attack. As I mentioned before I am a mechanical novice and know very little about this so any/all info will be greatly appreciated.
Thank you all.
The symptoms:
Thank you all.
