What is this doohicky?
  • pjsank
    • 77
    This is attached to the heater fan wiring. What is it?
    Looks a little banged up.
Name:	2012-05-19 19.17.25.jpg
  • Mercedesrover
    • 343
    Fan motor resistor. Yes, it looks pretty shot.
    www.seriestrek.com
    • disco2hse
      • Jul 2010
      • 451
      yup. Resistance is futile.
      Alan
      109 Stage 1 V8 ex-army FFR
      2005 Disco 2 HSE
      • TeriAnn
        • 1087
        Yes that would be on the low speed circuit of a 2 speed heater fan. There would be a switch position where the power fed directly to the fan and a low speed position where the wire wound resister would lower the voltage going to the fan motor and cause it to tun more slowly.
        Sorry I do not know the resistance or wattage of the resistor.
        Teriann Wakeman_________
        Flagstaff, AZ.
        My Land Rover web site
        • pjsank
          • 77
          Since touching it broke the wrapped wire, I no longer had a lower speed on the fan. Just attached the remains of the coiled wire to both ends of the ceramic cylinder and it gave me a lower fan speed. I think I can just rewrap it with new wire and get it to work at a lower speed. Any idea where this thing is supposed to be attached? All the images of the heater don't even mention this part, not to mention where it is mounted.
          • TeriAnn
            • 1087
            Resister wire is just that, a special high resistance wire. The end resistance is determined by the length of the high resistance wire.
            This could be someone's add on to get 2 speeds. usually the resister is mounted on the two speed heater switch between poles on the switch.
            Flagstaff, AZ.
            • I Leak Oil
              • 1796
              NAPA sells a generic 2 speed heater switch with a built in resistor. Works for me.
              • Howsomever
                • Jul 2010
                • 23
                As others have said this is special wire. Usually nichrome wire and length an gauge of wire plus properties effect overall resistance. This stuff can get hot and will hold together well over 1000 degrees. One common use besides high wattage resistors is for hot knives in cutting of foam and synthetic fabrics. Often this air resistance is mounted in the heater box specificially the air stream to help keep it from melting something else.
                Wayne
                1963 Series IIA 88, with 122,000 miles
                1984 D110, 3 door, 300Tdi, 127,000 miles
                • lincoln lass
                  • Jan 2012
                  • 36
                  This may help. http://uk.farnell.com/ohmite/l50j2r0...w-5/dp/1129678
