Ripped the Band Aid off! Build Thread and Advice Sought.
What.....? All I did was read the manual.It said in order to replace the clutch you need to take every nut and bolt off the truck, replace them and spend wayyy more money than you actually tell your wife you did. I was just following the manual!!!!Sean
1963 88'' IIa daily driver
1970 88"
1971 88"
authenticstoneworks.comComment
It is in good condition. The reason I am replacing is that the 109 was originally a hardtop and the PO cut the bulkhead behind the front seats to add a third fuel tank. I sold the full length hard top and purchased a pick-up top. The bed is fine for full length hard top or canvas top or no top at all. It is for sale I just have not listed yet. I may have an original tail gate to go with it.Comment
That was one of only a few times I launched a boat with it. I always pressure wash and spray with waxoxyl after I go on muddy roads or launch a boat.Comment
Yah, undo all the nut plates, nuts and bolts. They come right off after that. You will learn new body positions that you weren't aware that you are capable of, especially when getting after the mud shield upper fixings.Any secrets or tips for getting the front fenders and wheel wells off? Bulkhead off?
If you are working alone, a pair of vise grips on the other side is the best approach to nuts that you can't reach around for. Don't worry about snapping off anything, it is all still available.Comment
Pressure washed and went all over it with a hammer and screw driver. Only surface rust except where the rear portion of the area where the rear shock absorber attaches and very little there. I was able to get the flakes off with hammer and chisel and it was only minor on the top. Please see photos below and would like to hear thoughts and comment from the forum. Best regards,
One of the main reasons these frames rust from the inside out is that the outside, being more exposed to the air, dries quicker than the inside. Since these frames are mostly sealed it's hard to tell, maybe you could borrow a borescope and look inside.Gale Breitkreutz
'03 Disco
'47 CJ2AComment
looks great
aaron73 series III 88 2.5 na diesel daily driver
67 series 2a 88 RHD sold
88 RRC sold
60 mga coupeComment
Progress today. The Bulkhead was a tough one. I still have not decided on the whether to replace the chassis. Part of me thinks to do so since everything is apart, however, the original chassis seems to be in very good condition at least on the outside. Miles to go before I sleep.
Gad, those wings have me drooling even with the effed up looking diamond tread stuff on them. You just cannot get them any where.
Just buy a new galvanized chassis. Fooling with the old one, no matter what you do to it, you'll always wonder if it is bad inside.
I went with new on mine for this exact reason. Originality is of absolutely no consequence as far as value is concerned.Comment
