I have replied to several paint topics on here. Here is my 2c. First, I paint boats for a living, nice yachts etc.. Along with aluminum spars. So, that said I have not painted a rover. However, when I paint bare aluminum, I treat it with alodine wash first. There is a second part, but not needed. I use Alexseal or Awlgrip but mostly Alexseal. You can look them up online. Cheap? No. Worth it? I will doing mine with this stuff eventually. My feeling is if I am going through all this work, why stop short. But, there are plenty of paints out there. The issue of compatibility is interesting. You will know right away. Or, take some of the paint you plan to use, scratch the existing paint ( since you are repainting) spray some on and see what happens. I would say for the most part, unless its rattle can on there, you should be fine. Also, since you are stripping it, I assume you will sanding the bare panels as well. So, therefore removing "coating". I wouldn't worry so much. If Rover wanted bare cars, they would of left England that way..lol. Good luck.
PS: The aluminum oxide is a naturally occurring event, when it is left bare. This is not a treatment. The only time corrosion will be a huge issue is when it comes in contact with a different metal. Like stainless screws threaded into it. Then you will get bubbling etc. Then add water and you got yourself a battery..lol.
