Ok, so if you've seen my other thread, you know I just got my first Land Rover home.
I think its pretty much ready for the road... Except the turn signals. The PO told me he was having trouble with them, but thought his mechanic had fixed them by the time I picked it up. He hadn't, but it wasn't a deal breaker.
So, according to PO, before the mechanic worked on it last, the turn signals were all working when the headlights were off, but the left turn signal would work when the headlights were on. Not sure what was done to fix this and the rover has what seems like a bastardized rewire. Meaning, original harness with a lot of wires cut/disconnected and a lot of wires spliced in. Basically one hot mess.
Now, regardless of headlights on or off, the when the signals are used, the rear signal that is being used lights VERY bright, but the front lights VERY dim. In addition the opposite side also lights very dim. This on a vehicle that should not have 4 way flashers.
So again to sum up, when any turn signal is used, all 4 lights blink, the rear intended very bright, the others very dim... Where do I start?????
Oh, other information, she's a 1968 Series IIa and the turn signal switch is the original type (Tex Magna type with the rubber wheel for cancelling the signal).
Thoughts on how to diagnose, get it working? All other electrics seem good...
Thanks,
Dreddub
Thanks,
Dreddub
