Rhythmic ticking sound
  • gentilepiano
    • Jan 2008
    • 23
    My series 3 has a 5 main bearing 2 1/4 gas engine. The engine was overhauled with new pistons, valves, water pump, etc. a couple of years ago. I recently changed the oil, and adjusted the valves and when idling sounds as it should. When I increase the rpm a rhythmic clicking can be heard. it sounds like it is coming from the engine front. maybe the timing chain. The engine has plenty of power and runs smooth. The clicking sounds like(click-click-click-pause-click-click-click-pause etc) any thoughts???
  • stomper
    • 889
    A bomb attached to a lucas clock?
    • 4flattires
      • Aug 2007
      • 424
      Is this vehicle used regularly?
      Did this just start?
      Use the backyard engine stethoscope and determine the source of the noise. Place a long screwdriver on various engine parts and place your ear on the handle. Note the various sounds. Avoid humming and making up words to your newfound song.
      Naturally, have someone hold your frosty beverage when doing this.
      64 SIIa 109 all stock
      69 SIIa 88 all stock
      Old tractors
      New Harleys
      Old trucks
      • jonnyc
        • Dec 2011
        • 176
        Any ticking sounds I've ever had were exhaust leak, valve rockers, or timing-chain tensioner. Best of luck.
        • amcordo
          • Jun 2009
          • 740
          My ride ticks. It comes from something inside the transmission for me.
          Good story me.
          • willincalgary
            • Mar 2008
            • 127
            I once over tightened my valve cover and managed to get a minor knock from the top-front of the engine. More of a knock then a tick.
            ____________________________
            1959 Series II 88"
            "Grover"
            • east high
              • Jan 2008
              • 337
              This happens to me all the time. Almost like a ghetto torque spec for the valve cover.
              '67 sIIa 88
              • slorocco
                • 208
                When I first got my 109 the previous owner claimed that was the cause of the noise coming from the engine. It wasn't. Drove it like that for a few years and nobody could figure out the cause.
                To make a long story short, I finally determined to find the cause and started pulling things apart. Final verdict: Cam gear had worked loose on the front of the cam. Everytime a lifter would reach the peak of a cam lobe the cam would snap forward a bit. One of the additional symptoms was the that associated vibrations were tearing up distributors left and right.
                Probably not a common occurence and am hoping that is not the case with your truck.
                • cedryck
                  • Sep 2010
                  • 836
                  valves that need adjustment can sound loud, just a thought. cheers mate.
                  • mearstrae
                    • Oct 2011
                    • 592
                    On one of my vehicles, the ticking in front, was a bad bearing in the alternator. Just a thought...
                    '95 R.R.C. Lwb
                    '76 Series III Hybrid 109
                    '70 Rover 3500S
                    • willincalgary
                      • Mar 2008
                      • 127
                      I could tighten and loosen the valve cover fixings and the knock would come and go. Only completely convinced myself when I took the cover off entirely and the engine sounded perfect.
                      Totally a ghetto torque spec!
                      1959 Series II 88"
                      "Grover"
                      • gentilepiano
                        • Jan 2008
                        • 23
                        Hi Folks,
                        Thanks for the replies and suggestions.
                        I readjusted the valves while hot and to spec.
                        No change.
                        With a broomstick I listened to every part for the engine, including the block (everywhere) the timing chain enclosure, the alternator, waterpump, the head, everywhere!! The clicking seems to be coming from the thermostat housing(very loud). Impossible, but I drained the radiator,removed the thermostat, nothing loose, put it all back together, and it clicks as it did before.
                        Any ideas?????
                          Does it happen when the engine is cold?
                          • crankin
                            • Jul 2008
                            • 696
                            Originally posted by gentilepiano
                            Hi Folks,
                            No change.
                            Any ideas?????
                            You shouldn't have to drain your radiator to remove the t-stat. My suggestion, remove the t-stat all together and see if it ticks. Put it back together with out the thermostat in and see it ticks.
                            I might be that the flow of the water over the thermostat is rocking it back and forth? or something is loose.
                            Birmabright Brotherhood
                            Clint Rankin - 1972 SIII SWB
                            • gentilepiano
                              • Jan 2008
                              • 23
                              Ticks hot or cold!!
