Hey all,
Decided to drive my 109 from Burlington VT to Cape Cod (300-350 miles...so far). Im happy to report we are both doing well. The only issue Im having is that after all those highway miles the truck seems to want to run away on me. The RPMs will increase moderately, then take a second or two to return to normal idle speed, when I pull up to a stop light and put the clutch in. Happens a lot more when the engine is very hot. If I slowly downshift and very carefully come to a stop this usually does not happen. When its above idle at a stop I can tap the accelerator very lightly, the engine with grumble very slightly, then it will return to proper idle.
Ive adjusted the idle screw a little (6 month old weber) both ways with no affect (so I put it back to original settings from the its tune up last week). Ive also oiled all the connections in the entire throttle linkage system from the petal to the carb just in case it was sticking somewhere. No luck there.
Any ideas?
As a side note, the 2.25 (gas) seems to have seriously benefited from some time on the highway and some marvel mystery in the gas tank. Running great with a little more power after cleaning it out on the highway.
Ross
Any ideas?
Ross
