Years ago, I acquired an 88" IIA with a frozen motor (2.25 petrol) intending to restore it. Now I am. I took it all apart to find things in pretty good shape, probably lots of miles but little rust except in back of chassis, body good, etc. When I disassembled the motor I found all the pistons stuck so badly that I had to press them out of the bores which resulted in three of the four bringing what appear to be cylinder liners with them (the fourth liner stayed in the bore). One of the liners is split from top to bottom which I assume resulted from the trauma of trying to press out the piston. I can't find any indication in any of my manuals that these blocks were lined or that lining them was sometimes a part of a rebuild. What's the deal?
The truck is LHD but I don't know where it came from - there is some indication that it was at a US base in Germany so it may have been imported from there by a soldier - not sure why that would matter, though.
Is it possible that this motor was previously overhauled at which time it was found to be so worn as to not be suitable for oversize reboring resulting in the use of bore liners? Or, were some of these motors lined from new?
I just had a wild thought that perhaps the 2.25 petrol and diesel blocks are so similar as to allow either block to be built as the other with the installation of the proper head, ignition system, fuel system, and other parts. Can't imagine that would be the case and, even if it is, the assumption would be that the diesel blocks are lined and that my motor was built up from a diesel block. Is that even a possibility?
Just my guess though...
