I am almost done fixing/figuring out my 67 IIA. It runs great, but today I discovered that I have a lot of water leaks in it coming from everywhere, including the headliner seam between the rear seats and the cargo area. I will have to remove the safari roof to see what's there.
On another note, I am trying to figure out if it is normal for the parking lights to go off, once the headlights are turned on. Were they designed that way or is the wiring off?
Also, I can't seem to get the heat to work. I have a lot of air blowing out, but it is not warm. Any ideas? We just replaced the water pump and the truck doesn't overheat. Speaking of heater, I replaced the toggle switch and wired it the same as the old one. However, it seems both positions blow the same amount of air. I did notice that there are 2 unused tabs on the bottom of the switch.
Sorry for all the questions, but this forum has been my only resource to get this truck running right.
Thanks,
Ray
Thanks,
Ray
