Fuel pump recommendations pls
Yes, I run it with a Weber - there is a site that specializes in Webers and they say that this pump is just right in terms of pressure, flow, etc. for Weber carbs. It is a bit buzzy - I mounted it to the front of the fuel tank outrigger, so it's right below the passenger's feet.
I bought the optional oil pressure switch - the pump doesn't get any juice if the motor isn't running and producing oil pressure - handy in an accident.
TedComment
The stock mechanical pump of course designed to work properly with the LR carbs and happens to work well with both the Weber and Rochester.-
I had this issue with one of my trucks. It ended up being a very minor air leak in th line before the pump. The pump would not pick up fuel if it sat. If I primed the carb a couple of times it would start and run fine. After I tightened all fittings it worked fine.THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HTComment
