My Petro Thinks it's a Diesel
  • mjones1700
    • Jul 2012
    • 40
    My 109 SW 73 2.25 petro use to have this bad habit of dieseling after driving it. I had forgotten about that as it was in the shed undergoing a major restoration (body) over the past two years. Now that I'm driving it again, I noticed the dieseling. I'm not a mechanic. I've heard the most likely cause is timing but is this correct? Also, I'm not sure how to adjust the timing on it. The last time I did any timing work was with a friend 40 years ago. I remember us using caulk and a strobe light. Any advice? So what causes dieseling?
  • TedW
    • 887
    What are you running for a carb? I had this problem with my Weber until Les suggested that I purchase a fuel shutoff solenoid from our hosts. Problem solved.
    • superstator
      • Aug 2008
      • 298
      In my experience it's always been some combination of mixture & engine temp. Once you've shut of the ignition you shouldn't be getting spark, so timing should be irrelevant though it can influence engine temps. A fuel shutoff would fix it, but it seems like you're just masking the real problem that way.
      • disco2hse
        • Jul 2010
        • 451
        Run-on is annoying.
        Try here: http://mgaguru.com/mgtech/engine/ro101.htm
        Alan
        109 Stage 1 V8 ex-army FFR
        2005 Disco 2 HSE
        • mjones1700
          • Jul 2012
          • 40
          Originally posted by disco2hse
          Run-on is annoying.
          Thanks.
