I noticed my SII is weak and sputtering a bit. All ignition parts are new only 30km driven. Found second cylinder from back of engine is not firing. Spark plug is wet but clean. Also noticed a louder than usual tapping noise from the valves. I am going to work on it this weekend, starting with,
1. Check and clean dist cap
2. adjust valves.
3. Compression test.
What else should i be looking at.
Thanks in advance, I don't have much engine experience.
2. adjust valves.
