Gents,
I could use a little help with some simple circuits.....I pulled all 8 of the accessory lamps off of my SIII for painting (2 red brake lights, 4 yellow turn signals and the 2 white lamps, whatever they are for...) and have wired up new lamps.
I referenced a wiring diagram in a haynes manual, and while all of it's wire colors didn't match what I saw exactly, I'm pretty sure I got the wiring right (green to green and black to black for the 4 yellow lamps and 2 white lamps, green to green, black to black and red to red for the brake lights).
When I tested the lamps, the 2 brake lights lit up but didn't get brighter when I hit the brakes...probably going to test the switch to see what is up there.
The turn signal lamps only worked on the left side, but both the front and back on the left side worked, and they worked properly.
When I push the turn signal switch to the right, the flasher resistor clicks quickly, like it would if there was a missing bulb, and neither the front or rear lamp comes on, or the turn signal indicator lamp on the dash. I replaced the turn signal switch and the flasher resistor a little while back, but since the original lamps have been off the truck. I replaced it because I was getting an arc when driving the rover with the lamps off that caused the resistor to smoke and burn out....I'm guessing I need to trace the wires from where they exit the resistor to where they meet the lamps...unless there is something easy I am missing...
And then there are the white lamps on the front wings above the turn signals, that as I think about them, don't seem to serve any real purpose...they don't come on at all....and all of the fuses are fine...
I've got a multimeter and can trace every last connection on each of the bad circuits, but figured I'd access the collective intelligence and see if there are any simple solutions before I set out on a wiring safari.
