Not much of a problem but I find my S3 is difficult to start often, turning over but not catching. If I press the gas then it floods. But if I don't, then it sounds like it's not getting enough gas. Suggestions? There's a manual choke.
Starting issues
How does it idle and run? And which carb do you have. I just worked my way through them whole system so can possibly help but knowing a bit more would be good.1995 NAS D-90 Soft Top, AA Yellow
1957 Series I, Deep bronze green -
Hi,
I have a webber carb, oil type air filter, new fuel filters, 2.25 engine petrol. It turns over, sometimes sounds like I'm turning the ignition beyond the time I should, you know with that crunching sound, but it hadn't caught. I thought I'd sit there and try timing it, see when that sound happens and then try it a second less. I honestly don't know! Just trying to get to know this vehicle day by day.
1959 SII sold
1972 SIII RHD 88" (current project!)Comment
Hello, it's a manual choke, about sixty degrees out today, I used a little choke this morning, no pressure on the gas pedal. It took two tries and then started. So I'm thinking to practice with the choke on an off today, starting it in the driveway, come back again later in the day. Get a feel for it.
I guess I was just writing in the forum in case there was some hidden technique! It's just trial and error, right?
1959 SII sold
