despite a recent thread by another poster, I found myself foiled again on my 2nd attempt to swap hard top for soft top. This time I came up puzzled by the lack of long bolts/studs for the front, what goes in the big pipe/hole in the rear corners?, how does the roofside to tub seal (brand new) go on? etc..
I think I'm missing some hardware (the bolts/studs) and some knowledge.. after removing soft top and bows and messing with the 2 roof sides for a while I gave up in advance of the setting sun and reinstalled the bows and canvas.
Who knew the Brits could be so fiendishly clever (or I so dumb)...
This should be a simple thing right?
some questions:
How does one attach new roofside to tub seal? It's flat with a groove in it and doesn't like to bend around the corner in the rear. I tried putting the groove on the edge of the outer side panel and using tape to hold in place - this worked ok but wouldn't turn the corner so I cut the seal into 2 pieces - I'm thinking that A: this was a mistake and B: maybe the seal goes another way? The top seal is obvious and comes with a 90 degree bend in it - why doesn't the bottom seal have a bend like this?
I haven't even tried to attach roof to roofsides or heaven forbid - rear door...
some questions:
