Hello! I filled up my 1973 88" Series 3 more than I should have earlier today...gas did not overflow at the time, but after parking it, a bit of a puddle is developing under the tank.
Is this a common issue if one fills it too much? I think the stem was filled, fromt he tank to the gas inlet, and figure maybe that is designed to leak, or has a leak?
The tank was almost empty when I filled it up, and this was my first fill-up with this Rover (just brought it home from the garage).
Anybody else have experience with this?
I piled some dirt on the gas leak and will check in the AM to see if the fuel level actually went down any.
Any thoughts appreciated!!!
