Oh man, I think I tried to mess with one of these a while back and found out that it was some weird BS or BSF thread. If I had one in my hand, I could tell for sure.
There used to be an adapter which screwed into the head where it was origionally mounted but I'm afraid that it is NLA as I can't find one anywhere. If someone has a parts number for the adapter that might be of help.
Jim
I once ordered two from England that were too small. They were for a British car, just not a Land Rover. I was able to get one that was larger and correct from a US parts source. If you have an adapter, someone may have attempted to use a different sender at some point.
I'm trying to use an old water temp sender as an oil temp sender. Since I bought the dual gauge my cluster water temp gauge isn't hooked up so I got the bright idea to remove the mechanical oil temp gauge sender stick in the old electric water temp sender and try to use the old electric water temp gauge to read oil temp. Hope this makes some sort of sense.
Jim
