Attaching door seals, How?
  • pjsank
    • 77
    I need advice on mounting new door seals on a Series pickup cab.
    Pop rivets? Something else?
    Silicon RTV or not?
    thanks
  • busboy
    • Nov 2012
    • 202
    I used narrow strips of aluminum about 1/2 inch wide and quite thin then pop riveted them on one side of the "P" seal using short 1/8 aluminum rivets. They have been there for about 30 years.
    1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.
    • Les Parker
      • May 2006
      • 2020
      Or you could put 6mm washers between the head of the pop rivet (RNC960) and the seal.
      2p
      Les Parker
      • pjsank
        • 77
        Les, I assume you mean RNC690? What tool do I need to install that? Does not look like a pop rivet I could install with a Big Daddy Riveter.
        • jac04
          • 1884
          I have used 10-32 x 3/8" long stainless screws with small pattern nuts. Put a dab of red Loctite on each one and just snug it down.
          • busboy
            • Nov 2012
            • 202
            2p
            The benefit of using a strip of metal is the P seal is secured in place along it's entire length rather than just at each rivet.
            • o2batsea
              • 1199
              Yes, do this. You will thank yourself later. If you use button head allen you can't tell the difference between them and pop rivets unless you look closely.
              • Les Parker
                • May 2006
                • 2020
                pjsank,
                Good catch, ahem... just seeing if anyone was paying attention !
                Thanks for the correction.
                Les Parker
                • leafsprung
                  • 1008
                  Use aluminum semi tubular rivets as per factory - neat and clean and easy to install.
                  • TedW
                    • 887
                    X2. And yes, you will need the "Big Daddy" to install them. A wise purchase.
                    • VTRover
                      • 340
                      BY FAR the best way to get proper door seals for a Series is to take an angle grinder and cut off the lip edges. It's a nasty, job and you will need a good face shield and angle grinder. The payoff is you can install Defender door seals that run completely around the entire door and are 10000000% (really, THAT much!) better than the goofy trim, cut, pop rivet crap that was OEM. I've done it both ways and the Defender seals are the way to go.
                      • TedW
                        • 887
                        FWIW I installed Defender door seals on my 1970 IIA without removing the lip edges as described above. In my case they fit fine (if going on a bit tight in places). Incredibly simple to install.
                        I agree completely that Defender seals are far superior to the Series seals.
