My engine threw a rod at some point before I owned it, and I'm trying to decide what if anything to do about the damage to the crank... I doubt a regrind would get it all out, and other than the gouges to the #1 journal everything is in great shape with very little wear. Thoughts? I don't have a ton of rebuilding experience so i'm not sure if this is no big deal, or what.
Big end journal damage
Tags: None
If that one spot is below limits it could be spray welded then reground, take it to a place that regrinds cranks, they will have all the specs and can supply new bearings to fit the reground crank.1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.Comment
I will look into spray welding and regrinding. Too bad, I was actually getting some momentum built back up reassembling the thing!
Thanks for the info'67 109 NADA #413 - rebuilding w/ TDI & galvy chassis.Comment
