With RHD it's obviously not a US market model so a lot of the identifying features may not hold true. The side marker lights were added because of US DOT regs, The US dash may have been installed in a ROW(rest of world) vehicle before they were in a US only model. Or, someone may have used a IIA serial number to register a "less than legal" importation. Lots of possibilities here. Overdrives don't always give you more top speed, it really depends on the engine power at certain RPM ranges.
What would you do?
As some might know a UK license plate is issued to the vehicle when new and stays with it forever. In late 1961 they added an "A" to the end going from 6 digits to 7. As it was late in the year very few vehicles that year got the "A" but 1962 was a "B" so 1968 was an "H" the same as what's on the front of this one. What seems odd is the fact so many things say series 3. Perhaps the PO liked the look of the series 3 and changed over the mirrors and door hinges, the dash and grill, I don't think in 68 they had the dual circuit power brakes like this one does.
As for the Fairey OD like I said earlier you have to keep oil in it, a good synthetic GL-5 works wonders mind you mine is only around 30 years old.
Seems my memory is not as good as it was because I remember owning a "C" and a "G", "C" being 1965 so it was 1963 the "A" was introduced and "G" being 1969, so "H" IS 1970.Last edited by busboy; 12-08-2012, 09:34 PM.1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.Comment
You should look into rebuilding a original 2.25 gas motor and adding a overdrive if you are looking for a "easy" stock fix. We have three series trucks (2 88's and a 109) and all three will cruise all day long at 70-75mph on the highway. With overdrives the 88's return up to 18mpg, I've had a lot newer trucks that do much worse than that. I live in CT and drive the rovers through the madness of the city with no problem. Never once have I felt unsafe due to not being able to keep up with traffic or being able to stop in time. Look into a power brake booster too (if you don't have one already), that and a well maintained braking system are key to keeping these trucks safe.
I find the original 2.25 gas motor to be a great match for the truck. One problem comes due to the fact they can be very forgiving and run well past when they should have given up and died. This is a great feature in the bush but not ideal on I-95. This leads to slow trucks and bad performance. A well built (stock) motor will provide years and years of reliable service and in my mind should not be overlooked.
Good luck!Comment
When used correctly on hills a overdrive can actually improve your speed. When the truck is heavily loaded or pulling a trailer sometimes 3ed gear overdrive is the perfect gear. I split gears all the time, with the handle for the overdrive cranked towards the driver and a little practice it can all be done in one move with one hand. Its best only to use in 3ed and 4th where you don't put too much torque on it but I find reverse overdrive to be real handy in the mud. It gets the wheels spinning that much faster to help clear the mud.
Our 109" now has the high ratio transfer case. I do like it but always still reach for the overdrive feeling like I could get more from the truck with it. I think the high ratio box is great if you have a real strong motor, a 88", or really want to eliminate the weak overdrive and can deal with the taller gears.
With all that being said you have to understand them, they are a asset and a weakness. I have blown up two and now travel with the required parts to remove it and run without it.
Good luck!Comment
What a good idea to just keep the removed parts under the seat instead of in the shed, I'm relocating mine. Do you think you blew up the two because of lack of lubrication? Mine came new with a sticker for the dash saying to "check the oil level weekly".1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.Comment
The first one had the drive gear and nut fall off the transmission output shaft. This caused the teeth to get chewed up some as it was most likely loose for some time. It was fully rebuilt with new parts as needed. The other one let go internally. I cant recall what it was because I did not personally rebuilt it. It did have some oil in it at the time and was not run dry but the truck was running a ton of highway miles at that point. It was most likely overheated again and again due to low oil and the maintenance schedule of a 17 year old!
After that lesson learned, I check the oil often and can say this one has been on the truck for almost 12 years now with no issue. But you will always find those replacement parts under the seat in my truck!Comment
Tell me about the replacement parts.. I bought my truck with the OD installed (Fairey) and don't have the original cover or other required pieces to effect a roadside removal should it fail - what is needed?The first one had the drive gear and nut fall off the transmission output shaft. This caused the teeth to get chewed up some as it was most likely loose for some time. It was fully rebuilt with new parts as needed. The other one let go internally. I cant recall what it was because I did not personally rebuilt it. It did have some oil in it at the time and was not run dry but the truck was running a ton of highway miles at that point. It was most likely overheated again and again due to low oil and the maintenance schedule of a 17 year old!
After that lesson learned, I check the oil often and can say this one has been on the truck for almost 12 years now with no issue. But you will always find those replacement parts under the seat in my truck!Mike
1969 Series IIa 88 2.25 petrolComment
It's been 30 years since I did mine but I think it was just the cover and a single gear, might need a new lock washer.... I'll dig my bits out in the spring and put them under the seat. Could look up the installation instructions, that might help.1971 series 2a 88, series 3 trans, Fairey OD, owned since 1978.Comment
